Countdown timer
You can use the countdown timer to count down from a preset time to zero. The timer makes a short sound every second during the last 10 seconds and sounds an alarm when zero is reached.
You can show/hide the countdown timer from the start menu under Displays » Countdown. Toggle with Next.
To set the countdown time:
  1. Press Next to until you reach the countdown timer display.
  2. Press View to adjust the countdown time.
  3. Set the hours and minutes with Start Stop and Light Lock. Accept with Next.
  4. Press Start Stop to start the countdown.
countdown timer Ambit3
You can pause/continue the countdown by pressing Start Stop.
