Suunto Vertical 2 User Guide
Touch screen and buttons
Suunto Vertical 2 has a touch screen and three buttons you can use to navigate through displays and features.
Swipe and tap
  • swipe up or down to move in displays and menus
  • swipe right and left to move backwards and forwards in displays
  • tap to select an item
Upper button
  • press to move up in views and menus
  • from watch face, long press to define and open shortcuts
Middle button
  • press to select an item
  • keep pressed to go back in settings menu
  • from watch face, press to open the pinned widget
  • from watch face, long press to open settings menu
Lower button
  • press to move down in views and menus
While recording an exercise:
Upper button
  • press to pause and resume the activity
  • keep pressed to change activity
Middle button
  • press to change displays
  • long press to go back to the previous display
Lower button
  • press to mark a lap
  • long press to open the control panel where you find the exercise options
  • when the activity is paused, press to end or discard the activity
Indice
