Suunto Vertical 2 User Guide
Indice
Indice
- Multisport exercise
Multisport exercise
Your Suunto Vertical 2 has predefined Triathlon sport modes that you can use to track your Triathlon exercises and races but if you need to track another sort of multisport activity, you can easily do so directly from the watch.
To use multisport exercises:
- Select the sport mode you want to use for the first leg of your multisport exercise.
- Start recording an exercise as normal.
- Press and hold the upper button for two seconds to enter multisport menu.
- Select the next sport mode you want to use and press the middle button.
- The recording with the new sport mode will start immediately.
You can change sport mode as many times you need during one single recording, including a sport mode you used previously.
